I have been trying a few different things. Some carving and some more like signs.At this time most end up as the top of a box or the face of a clock or shelf.
BT 32 Standard
2.2 HP Spindle
Aspire Sofrware
That stuff looks Great Phil!
Is it the amount of finishing time after it comes off the machine you're having the problem with?
For kicks and giggles, try a small test with a lower stepover and against the grain like I do?
Yes, it is the sanding after if comes out of the machine. I need to buy stock in Dremel tools LOL.
I usually go at a 45 degree angle to the grain. I will try the smaller step over of 5% and cross grain instead. I also set plunge rate = feed rate.Thanks for the advise.
I have some V-Carving of letters that I am planning in the near future on a concept for a new product for Christmas and occasional gifts. I know its a little late for Christmas, so thankfully this is not how I make a living.
I may not do any 3D carving for a while. When I do I'll post a picture and let you know how it went.
Thanks again
BT 32 Standard
2.2 HP Spindle
Aspire Sofrware
Phil,
Several times I've run circular models with an offset finishing toolpath....and the worst of the finish was always at 45 degrees to the grain...so maybe that was part of the problem?
Maybe try 2 small samples...one with, and one against the grain...and leave unfinished in shop as a reminder
Happy Holidays!
Sounds like a great idea. I will run a few small sample carvings of a butterfly on the same piece of maple or cherry to keep the variables to a minimum. I'll do one with the grain, one at 45 degrees and one across the grain. I will use a speed of 17,000 rpm, a plunge and feed rate of 60 and a 5% step over rate on each. This should be interesting.
Thanks again
BT 32 Standard
2.2 HP Spindle
Aspire Sofrware
