HSD 2.2 HP 220V 1ph Spindle. Vac table ported. 2 fein vacs. Vac hold down pump with 10 pods. 4 + sheets of LDF (spoil board material). Spoil board surface bit plus additional tools. Laptop, etc. Finally moving, must sell, $9800, obo.
The vac pump is for pod work, not flat table sheet goods. It is a small gast pump. I usually use 4 to 10 pods depending on the piece. Machine was used mainly for 3D carving so as is sits now, I have a piece of white 3/4" thick white melamine bolted down to the spoil board. But I do have the two fein vacs (like a shop vac looking thing), that the guy before me used for sheet material. It is plumbed out but I have never used the machine for that. See attached the kind of stuff I build, this was the center portion of a french mantel, it also had the legs on the side. From the photos, all of the face is carved (not applied) except for the small molding under the lid. french2.jpgfrench1.jpg
