Had to duplicate these round moldings for a 150 year old house. careful alignment is crucial when flipping for the bottom side cuts!
Ron Sloan
Great job Ron!!
Don
www.dlwoodworks.com
Nice work Ron.
WWW.MillerMarineProducts.com
Proto Trak DPM CNC Bed Mill
Brand X Industrial router
Sharp SVL-2416SE-M VMC
So I looked at the first pix and said to myself, I can do that! Then I looked at the second pix and . . . . . . . Well done! Russ
AKA: Da Train Guy
Good work Ron. I am always impressed when someone makes the effort, and has the skill to exactly replicate old wood work! Chuck
Chuck Keysor (circa 1956)
Columbo 5HP spindle
Aspire 9.0, Rhino 5
Nice job Ron ~ Just a critique/observation/question....
In the 1st pic, the repro part appears to have a slight divot/flat/cusp at the apex of the round. This leads me to believe from experience that a roughing pass wasn't run & the ball gouged the top surface on the first pass. Was this the case?
Not trying to take anything away from your great work...just curious & looking to compare notes since I had this happen on a teak part last week.
Hi Brady,
I noticed that, too. A roughing pass was run, but the material was either slightly under 1.75" thick or I forgot to center the model in the material, which left a slight flat on it. As you can see from the original piece, after years of sanding, they were anything but round, so a slight sanding worked well for this piece. ;-)
Ron Sloan
Thanks Ron. Yeah that's a tricky part to get right wit the paint still on
