Results 1 to 5 of 5
Thread: Touch off for x and y
    Oct 2017
    Default Touch off for x and y
    I have a new 48x96 PRSAlpha.
    Is there a way I can touch off the spindle to the edge of material in x and y similar to the way we do z? Milling slots in aluminum extrusion, I need position accuracy.
    Or what is the best practice with this machine.
    jerry
    Apr 2007
    Marquette, MI
    Yes there is. You can electrically connect your zzero plate to the extrusion, but you will have to write a short sbp code to move and then stop the action. There is a good example of this in both the XYzero and Z zero routines.
    GCnC Control
    Servo Controller Upgrades
    Albert Einstein
    Oct 2017
    ...There is a good example of this in both the XYzero and Z zero routines.
    Thanks Gary, Where would I find this example?
    jerry
    3-axis Zero Plate via ShopBot Store
    Documentation for 3-axis Plate - (including what files to run with it)
    Or you can make your own. Files to run it included.
    https://1drv.ms/u/s!AsPqyLrhnhkRgbopgpP86_XTEfJ43A
