Results 1 to 4 of 4
Thread: Reflective
    Jan 2011
    Springfield, IL
    Default Reflective
    Got a piece of 3M™ Diamond Grade™ LDP Reflective
    Sheeting Series 3970 ... applied and carved on clear pine... painted... coated with tompson's water seal. The neighbor had this OLD stuff in his shed and we decided to try it out. He's had same material stuck to unfinished mailbox pole for over 5 yrs... so i guess this will last at least that long on carvings. I hobbyist... not sign maker or work for profit org. We like it and wanted to share.IMG_20171113_133621_504.jpgIMG_20171117_133549_871.jpg
    Jun 2007
    Hampton Roads, VA
    Thats cool stuff. Thanks for sharing. Did it machine clean?
    Jan 2011
    Springfield, IL
    Very Clean. I do re-run the v-bit path as a cleanup. Very little sanding, mostly on chamferred edges.
    Jun 2007
    Hampton Roads, VA
    Good to know. Thanks for the specifics on the sheet.
