Results 1 to 6 of 6
Thread: Fein Vac
    Default Fein Vac
    Does anyone know where I can pick up brushes for a Fein Vac. I just had to free them up on one of mine
    If this part (assuming Turbo III/9-77-25) is no longer available, any decent electric motor repair place should be able to make you a set.
    cnc routing, portland or
    worst case you can replace the motor for about 150.00
    I had a bunch of different brushes and found some that were the same. Changed them out and now it runs like new.
    Jan 2007
    Henrico, NC
    Old topic but hopefully you remember how the brushes came out?
    Jan 2007
    Henrico, NC
    Disregard the above message. The brush assembly I had tried was being troublesome. When I tried the other it came out as expected realizing a bigger 'hammer' was required for the first one. Problem solved.
