Results 1 to 10 of 13
Thread: cutter veering off circle
    May 2006
    , SW PA
    Default cutter veering off circle
    Just started doing this the past couple times. When cutting a circle, say 3/4" material. When the bit is getting toward max depth it suddenly veers off the circle and starts cutting into the material. I thought maybe I needed a new end mill, changed it out and it worked ok, then today did it again. I notice especially when cutting corian. Any ideas?
    Bob
    Feb 2013
    River Fall WI
    Need more info.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    Marietta GA
    Quote Originally Posted by Kyle Stapleton View Post
    Need more info.
    Agreed...
    not sure how much “off circle” we’re talking here.
    May 2006
    , SW PA
    using a 1/4" em, either up or downcut, cuts straight across the wood. Like it catches a corner and goes haywire. Going 180ipm
    Bob
    What happens if you run it at 90 IPM?
    Use a piece of scrap. Extra points for pics or video...
    Guessing this is a Standard and not Alpha.
    May 2006
    , SW PA
    This is a prt with the RBK contol box and new motors. I will slow it down and hope that is it.
    Feb 2013
    River Fall WI
    A downcut in corian is a bad idea, you should be using a "o" flute.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Marietta GA
    Quote Originally Posted by bob_reda View Post
    Bob
    the two descriptions you’ve provided are incongruent...
    do you have a picture you can share?
    May 2006
    , SW PA
    I'll try and draw something to make it less confusing
    May 2006
    , SW PA
    Hope its understandable. It happened in both corian and in wood
    Bob
