Thread: Z Zero question
Hybrid View
    Jan 2009
    Texarkana, Texas
    Default Z Zero question
    Happy New Year all. Have a question. Set up an new laptop computer for my PRT. Downloaded the appropriate Controller software. Setting up zeroing to proximity switches with offset on the X by 7.0 inches and .5 on the Y. All is perfect. Z Zero to the touch plate and it measures .121. Then returns to 1.0 inch per the screen. (see second picture) measured the distance between the tip of the bit to the surface and measures .5. (see first picture).
    When I adjust the safe z height to 2.00" and measure, we get a proper measurement of 1.0". What have I done wrong or need to adjust?
    Thank you,
    Terry
    Got a 7.2:1 motor on the Z? (as indicated by either 7.2 on name plate OR in small letters towards the bottom 0.25 deg step) - If so, double the UV for the Z exactly by 2.
    If Z motor = 7.2:1, then Z UV = 2291.831 X 2 = 4583.6628
    Be sure to also install the firmware first via UI if you haven't already. Then change the UV/VU.
    Jan 2009
    Texarkana, Texas
    Thank you Brady,
    The stepper motor is 0.25 deg/step. Firmware was updated this morning. Went in and changed the figure as you stated and we are now on the money.
    Happy New Year!
