PIX-30 For Sale. Excellent condition, includes all original materials, shipping box, manual, software, supports, clay, AC adapter. Serial RS-232 C interfaceScans by touch probe to min pitch of 50 microns. Outputs DXF, IGES, VRML, STL, 3DMF, BMP, Grayscale, ASCII. Max scanning volume 12" x 8" x 2.375". Max weight of item 11lb.
$250 + shipping
From the manufacturer:
The PIX-30 can scan objects as large as 304.8 mm (width, X axis) x 203.2 mm(depth, Y axis) x 60.5mm (height, Z axis). The PIX-4 scans sizes up to 152.4mm (width, X axis) x 101.6 mm (depth, Y axis) x 60.5 mm (height, Z axis).For additional height, an object that sizes up to 130 mm (PIX-30) or 70 mm(PIX-4) can be set and the top 60.5 mm part of the object can be scanned.PICZA's high performance enables a scanning pitch of 0.025 mm (Z axis) and0.05 mm to 5 mm (X axis and Y axis).Due to precision Piezo technology,PICZA scans a wide range of objectsincluding soft objects like clay andfruit etc. that conventional contactscanners are very difficult to scan.PICZA can even scan glass, impossibleusing optical scanners because thelight beams pass through the glass.
Jim
96 x 60 PRSalpha, 5HP Colombo spindle, Custom indexer, Custom vacuum table, Custom Fire Extinguishing System
