Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 3d printer
    Marietta GA
    Default 3d printer
    Anybody here have any experience with 3d printing?
    I'm trying to source a 3d printer to play with here at work for less than $1200.00 or so.
    There's TONS of "top ten" 3d printer lists to be had on the interwebs, but I'd prefer to hear from folks who have actually used the hardware, not technical writers who are paid for glowing reviews.
    Buy a new genuine Prusa. It's cheap to buy, has excellent electronics and innovative features.
    After you fool with that, you might want something a bit better like an Ultimaker2+ or 3....or if you want to do bigger things, the CR-10 S5 isn't bad - although things cost what they do for a reason. You'll be doing upgrades to the CR-10 sooner than later.
    Like I said, the Prusa is hard to beat. (the one shipped directly from Prague...NOT a clone)
    Oct 2009
    Larrabee IA
    Robtown Sent you a private message
    May 2014
    MA
    I've worked on Prusas, I own two Makerbots, a Dremel, and an Ultimaker 2+ and a Monoprice Maker Select Mini. The best one I have in terms of quality is the Ultimaker. The worst one is the Makerbot 5th gen. They're both in the 3K range. The standout great in my fleet of printers is the Dremel 3D40. It's 1200 bucks and has been the most rock solid reliable printer I've owned to date. The print quality is very good, and I've never had it jam and I use it a lot. I also love tha auto build plate leveling and the full enclosure on it.
    The Prusa is a very cool printer. Prusa is the tinkerers printer. So if you want to learn about, fool with and modify a printer (and run weird filaments and such) a Prusa is great. If you want reliable prints out of PLA only, Dremel is great value for money.
    Honorable mention goes to the Maker Select Mini. At $200 bucks it's an insanely good deal, but very small and not nearly as full featured as the other ones.
    Quote Originally Posted by EricSchimel View Post
    I've worked on Prusas...
    When I mentioned a Prusa, I meant a brand spanking new i3 Mk3 - which has a lot of cutting edge features not found yet on ANY other printer, including my Ultimaker...It is vastly improved compared to previous models. It's almost unreal that they can sell them for $750/$999 kit/assembled. There are a LOT of knock off/clones out there with the Prusa i3 designation that are complete junk. It costs more to get them right than to just get a genuine one. Don't take my word for it....see what Tom says about it. Is it 'the best' 3D printer? No...but it IS a good value for the money - especially if you are not sure if you are even going to use it yet.
    It really all depends on what you want to do with it. Don't be fooled - 3D printing is both harder and easier in a number of way compared to CNC. You're going to need to be good at manipulating 3D meshes and make them watertight.
    Rob - What do you aspire to do with a 3D printer?
    Attached pics of model that was scanned & printed on a MK2 Prusa i3 @ .2mm layer height. About 190mm from the back of the head to the nose. Took about 25hrs. I like making parts while I sleep
    Change nozzles and you can do even smaller things too...It's great for mechanical models too and of course, prototypes...or for just making things to mess with your dogs
    Marietta GA
    That is pretty impressive...
    Aug 2013
    Clayton, NC
    Like that printer, I've been looking myself and damn if it's not confusing all the different ones out there!!!
    About a month or two delay in ordering the MK3 unfortunately.
    Daniel E.
    Porter Cable Router
    Vacuum Table w/ 2 Fein vacs
    Aspire 9.0
    Quote Originally Posted by tri4sale View Post
    It's been a long wait since they announced it last year. My brother got one right before Christmas...and it wasn't for the kids! I opted to wait on the MK3. My three Mk2s are doing what they are supposed to...making parts. I've got a toolchanger setup for my ultimaker that will let me run dual filament - one for water-soluable support structures and the other for regular filament.
    Yes, there are a lot of variations out there, but just like CNC machines, in reality, there are only a few different types of control systems and almost everything else boils down to mechanical components.
    As with a CNC router, get your first one that has a good support network - because you WILL have moments of frustration and you'll need a shoulder to cry on.
    There are a lot of variables to contend with...but 8 year olds run these things - so yanno...
    May 2014
    MA
    It really depends on what you want out of a 3D printer... Prusas are awesome because they're so flexible and hackable, but they don't hold up as well in continuous use. I've had to rebuild several of them that are in use at schools (they're printing nearly 8 hours a day) and they tend to rattle apart. Granted that's a very extreme use case for what they were designed to do. The Ultimakers are a bit more resilient.
    Brady, a Prusa is likely the perfect printer for you because you know your way around this stuff really well. I recommend Ultimakers to experienced people who want some good flexibility in terms of filament types, but don't necessarily want to mess with rebuilding a 3D printer. For straight up school settings the Dremel is one of the best.
    Nov 2012
    Lancashire, UK
    Default Ask yourself...
    Dear Rob
    I'm not going to get involved with 'who's is the biggest or best', but.. When I bought our first 3d printer, I got it second hand and at a bargain price. And if I were to do it again I would have asked myself the following.
    - How to Choose Between Cartesian and Delta 3D Printers
    https://www.fargo3dprinting.com/choo...a-3d-printers/
    - Heated bed or not!
    http://bootsindustries.com/heat-bed-3d-printing/
    - Filament
    http://www.fabbaloo.com/blog/2015/7/...inter-filament
    http://3dprintingfromscratch.com/com...ypes-overview/
    - You'll need design software
    https://www.dobot.cc/resource/top-15...beginners.html
    - You'll need slicing software
    What is slicing software and what does it do?
    https://www.goprint3d.co.uk/blog/wha...at-does-it-do/
    - Is there a user forum and manufacturer support?
    You won't know this when you buy it, but how easy is it to clean out the nozzle. 3D printer filament must be kept clean, which can prove difficult in a wood cutting CNC environment. Any dust on the filament gets carried in and clogs up the nozzle.
    Anyway best of luck, I'll watch this thread with interest. Please post when you've made your choice.
    Sincerely
    Martin
