Results 1 to 9 of 9
Thread: Ground Wire for DC
    Aug 2008
    Plympton MA
    Default Ground Wire for DC
    I have a solid copper wire that runs from the main trunk of my dust collection ductwork down a flexible hose to the dust boot on my machine. Issue is that, over time, and repeated movement, it periodically breaks. Is there a better alternative? Among other things, I wondered about hanging a small link copper chain inside the hose...
    Nat Wheatley
    Plymouth Custom Closets
    www.plymouthcustomclosets.com
    Apr 2007
    Marquette, MI
    A stranded copper wire?
    Gary Campbell
    GCnC Control
    GCnC411(at)gmail(dot)com
    Servo Controller Upgrades
    Albert Einstein
    Aug 2008
    Plympton MA
    Quote Originally Posted by Gary Campbell View Post
    Hadn't seen one that didn't have a plastic coating, but will do search now...
    Nat Wheatley
    Aug 2008
    Plympton MA
    Thinking this might be what I'm after:
    https://www.homedepot.com/p/Westingh...caApjSEALw_wcB
    GCMF
    Nat Wheatley
    Delray Beach, FL
    You can get that in the length of your choice at any electrical supply house if all HD has is precut lengths.
    Aug 2008
    Plympton MA
    Quote Originally Posted by bleeth View Post
    Thanks. The supply house is actually closer to me than HD, so that might be the better route anyways...
    Nat Wheatley
    My dust collector uses a 5" hose that has a copper clad wire integral to the tube as the coil that holds the hose open. I ground it on both ends. Never had a problem with static.
    Most big box stores have .023 copper clad MIG wire on a 1# spool. Works great. Wrap it around a rag and let the DC pull it through the hose while you throttle it.
    Aug 2008
    Plympton MA
    Thanks Brady!
    Nat Wheatley
