Had a dovetail bit slip for the first time ever. Utilizing Gary C's jig and part file for years - hundreds of drawers, no slippage.
In this instance, I had niether extra bits nor collets on hand. As I was 2/3 of the way through the batch, something needed to be done so I could finish. I pulled things apart and saw the score marks left on the bit's 1/2" shank and inside the collet - what to do?
As a last-ditch effort, I used a green scotch brite pad to alleviate the marks on the bit's shank by spinning the bit with one hand while holding abrasive pad stationary on the shank, and
(cringe here)
rolled up a 120 grit micro-mesh sanding disk, and spun in same rotating fashion to score inside the collet. Indeed, it held firmly for remainder of the job, and the friction was certainly noticeable as I loosened to remove the bit when done.
So... question is, would this be an acceptable practice for more taxing procedures, such as milling dovetails in hard maple, or am I tempting fate for an altogether worse issue with prolonged use (like a bit stuck in collet)?
Mechanically speaking, makes sense to score the surfaces in this fashion, as the abraded grooves interlocked, avoiding bit from slipping down and out again. However, logic insists there's a very good reason all this tooling comes highly polished...
Seeking enlightenment
Jeff
