Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Is it ever OK to put screws in your bleeder board?
    Mar 2008
    Radford VA
    Default Is it ever OK to put screws in your bleeder board?
    I am helping a friend of mine setup a vacuum system on a Shopbot that he is in charge of at a local college. We are going to make the plenum out of standard MDF with 6 zones. Then glue down a 3/4" thick piece of Trupan for the bleeder board.
    I've had my own Shopbot many years without a vacuum table, so I am new to vacuum systems and I am accustomed to screwing everything down. Is it heresy to use screws to hold down small irregular pieces that don't go all the way through the bleeder board?
    I know you can use a sacrificial piece of plywood and screw to that and hold with the vacuum. But, I just wondered if your could screw into your bleeder board without ill effects in order to save turning on the vacuum for small jobs.
    PRT Alpha with 7.2 upgrade, indexer, and PC router
    Feb 2013
    River Fall WI
    Yes, that is fine we do it when small parts just will not hold.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    May 2014
    MA
    You can also put a "carrier" board on top of your spoilboard and vacuum it down. Then you can fire screws into that carrier board. I've done that before to avoid putting screws in my bleeder board, especially when the bleeder board gets real thin and there's not much meat left for screws.
    I've even routed a little channel into the underside of a carrier board to direct a lot of suction at a smaller part.
    Nov 2012
    Lancashire, UK
    Default No screws or glue!
    Dear Kyle
    We have a series of thin laminated boards that we place next to the 'part' to (a) help with the vacuum and (b) help hold the 'part' from moving see attached picture.
    Also we use a 12mm thick MDF sacrificial board. We don't glue it down as we change it every two or three months. There are some location blocks around the edges then use the vacuum to hold it 'flat' while it is surfaced also while it is being surfaced we place masking tape round the edges to stop it moving.
    Any way that's my two penn'orth.
    Sincerely and in good faith
    Martin
    Nov 2012
    Lancashire, UK
    Default Seal the plenum
    Dear Kyle
    I forgot.
    To maximise the 'vacuum' don't bleed air through the plenum. When you have machined the plenum zones, seal it with lots of coats of sealer and when you think you have finished sealing it - give it another coat. When we bought our first machine (second hand) the guy said his best decision was a vacuum bed and gave us the 'more sealer' advice. Of course we didn't follow his advice and gave it two coats of sealer, it looked fine. For months we couldn't understand why everyone raved about 'vacuum' we were putting screws in all over the place. Then while changing the sacrificial bed I decided to give the plenum another couple of coats of sealer. We couldn't believe the difference. We gave it more coats the next time we changed the bed.
    Remember; vacuums don't 'suck' down, they evacuate the air from underneath and atmospheric pressure pushes down. If you could evacuate all the air then the maximum hold down pressure (at sea level) would be 14.7 pounds per square inch. As soon as the air bleeds out from the vacuum you start to reduce the hold down. I've even taped over behind the kerf to help prevent bleeding the vacuum.
    Now I've had more than my two penn'orth.
    Again sincerely and in good faith.
    Martin
    Feb 2013
    River Fall WI
    Martin,
    Thanks, great tips for others.
    Your picture does not show a small part and the forces of a 3d cut are normally not the same as a 2d profile.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    I split my spoil board into 4 sections with a 6mm piece of sintra between each. My plenum is 1 inch thick sintra also. The reason is I found out that when I was only using 1 zone I had a piece of material all the way over to the other side and at the other end of my table and I went to push it it was held down. I now get better vac hold down
    Nov 2012
    Lancashire, UK
    Dear Kyle
    It is the only photo I have showing how we can 'zone out' each part of the table with laminated boards. Laminated because they don't bleed air. I don't have photos but we use this technique with the 19mm roto tip cutter when cutting vision panels in 54mm fire doors. That really tests the hold-down.
    Martin
    Mar 2008
    Radford VA
    Martin - Can you give specifics on what you used as your plenum "sealer"?
    Dec 2008
    Diamond Lake, WA
    Here's what I do. 1" MDO with T-tracks and clamps. Vacuum system holds the MDO firmly in place. Eliminates having to put screws into your spoil board. I've got two of these to provide 4' x 8' T-track hold down.
    Don
    www.dlwoodworks.com
