Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Vac table PVC flange and ball valve source?
    Mar 2008
    Radford VA
    Default Vac table PVC flange and ball valve source?
    I'm getting ready to setup a vacuum table. I'm currently laying out my piping. It seems like the consensus is to use 3" piping for the manifold and then 2" to the table.
    Does anyone know where to get 2" PVC 90 degree flanges that mount to the bottom of the table? See the pic attached that I took off the Shopbot website. The only right angle flange fittings that I can find are for household central vac systems. I found some schedule 80 straight flanges at McMaster but they were pretty pricey. Anyone have a source that they could share?
    Anyone used these 3" ball valves from Amazon? The ones at Home Depot are double the price and are special order. https://www.amazon.com/Inline-PVC-Ba...l%2Bvalve&th=1
    Thanks!
    PRT Alpha with 7.2 upgrade, indexer, and PC router
    Aug 2013
    Clayton, NC
    I got everything I needed from a local plumbing supply house, price was on par with local Lowes but they had better selection of some parts like the ball valves and flanges.
    Daniel E.
    Porter Cable Router
    Vacuum Table w/ 2 Fein vacs
    Aspire 9.0
    May 2014
    Tucson, AZ
    check out the thread below before you use ball valves, there is a better solution. Ball valves will become problematic with repeated use. I can look tomorrow and let you know where I bought flanges.
    Jim
    http://www.talkshopbot.com/forum/sho...326#post199326
    Jim
    96 x 60 PRSalpha, 5HP Colombo spindle, Custom indexer, Custom vacuum table, Custom Fire Extinguishing System
    May 2014
    MA
    I'm using similar ball valves on my setup and they work fine. They have a little stickiness when you first turn them. If you were flipping them open and closed hundreds of times a day I could see it getting old, but if it's only a few times a day, or even hour they're just fine for me.
    Like you I ordered mine online, but I got everything else locally.
    Sep 2014
    Poughkeepsie, NY
    Just use a regular 90 with a nipple into the flange or a street 90 and the flange. All the pieces to build the system are stock plumbing parts.
    Before you get rigid pipe, check out 2" flexible PVC. That's what I used. It's 1/10th the trouble to install and doesn't require elbows.
    I'm curious why you want to use 3" ball valves? I'd think 2" would be fine. I used a 3x2x3 T to make my manifold and attached 2" ball values.
    Apr 2011
    New Jersey
    What I used: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Only a few bucks more than ball valves but easier to use and should last longer.
    May 2014
    MA
    This is my setup:
    http://www.talkshopbot.com/forum/sho...esign-thoughts
    Let me know if you've got any questions
    Mar 2008
    Radford VA
    Thanks everyone. I have settled on the 2" Valterra valves for my manifold.
    I still cannot find any 2" 90 degree flanges to bolt to the underside of the table. I spent an hour searching online and went to 2 local plumbing supplies. If anyone knows where to find them, I am all ears. If I can't find any in the next day or so, I'm just going to take JMCS' suggestion and just put a street elbow into the plenum hole and seal it off with silicone.
    Coryatjohn - Is the the correct flexible PVC to use? https://www.amazon.com/HydroMaxx-Fle.../dp/B003XRVJHK
