Hello Bob..... You are referring to a general rule of thumb, which is used reduce the chances of snapping off a bit. If you are cutting Styrofoam, you could of course take much deeper passes. If you are cutting brass, well, you could only take cuts of maybe .01" per pass. But for cutting run of the mill wood, plywood, plastic, well, not having the pass depth not exceed the diameter of the bit is a reasonable starting point. And, I am no expert. Many people here are experts, and this topic has come up many times before.
I order to search this form to look for the information you want do a google search for: bit cutting depth site:talkshopbot.com
Well, the general format to do a google search on this forum is: SUBJECT XYZ site:talkshopbot.com
You can put quotation marks around important phrases, or use * as a wild card.
Anyway, even what I just told you here, is what I have learned here on the forum. And, I have a notebook for Shopbot, where I write down important things I see here on the forum.
Good luck, Chuck
PS: I didn't know your name, and I have never met a Bob I didn't like, so I called you that...……….
Chuck Keysor (circa 1956)
Columbo 5HP spindle
Aspire 9.0, Rhino 5
