Results 1 to 10 of 12
Thread: intersecting components
    Creative Solids, Fairfield Glade Tennessee
    Default intersecting components
    ok - thoroughly enjoying 9.5!! and my first indexer project is a nice challenge. need help with intersecting components - where the spiral begins and ends. i used a profile to make that entire piece then added the spiral in the center. my thought is that there should be 5 profiles - the two ends, the two doughnuts (if you will) and a center pole on which i put the spirals. appreciate your thoughts and suggestions
    For my first indexer project, I made a cylinder...
    PRS Alpha 96x60x12
    Actually my first were rolling pins, made from solid surface. But those were manual cuts, this will be the first using Aspire
    I suggest experimenting on 4x4's from your local big box store. Great material for playing with an indexer.
    PRS Alpha 96x60x12
    Got one from hd - it is the next step after some final tweaking - the 4x4 was your idea and a good one. Later today or tomorrow we shall see just what happens.
    Just an up date - ran out of time to do a test run - needs to wait until i get back from trip - but i solved the problem of how to intersect components - no pictures now, but making progress learning aspire 3d and indexer software - btw training videos suppied by Vectric are exellent and very helpful
    Mar 2005
    San Jose, CA, USA
    If you are interested, it is possible to do this design using 2D toolpaths and a larger diameter form tool (point roundover). That way it could be machined in about 30-40 minutes.
    Attached Files Attached Files
    - Randall Newcomb
    10 fingers in, 10 fingers out
    another good day in the shop
    Quote Originally Posted by rcnewcomb View Post
    I totally agree there. Besides being quicker, the results will likely be better too.
    PRS Alpha 96x60x12
    Came up with the same idea and ordered such a router bit - my current ‘challenge’ is that i am now in southern florida visiting my wife’s sister and family..... so when i return i plan to try the point round over - cheers
    don
    Mar 2005
    San Jose, CA, USA
    I think you will be pleased with the point roundover. A large ballnose also works well with the indexer.
    Using vectors that are close together will "overlap" when cut deep enough and generate what looks like a 3D design.
    RotaryFlute.zip
    - Randall Newcomb
