Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Composite Wood?
    Mar 2018
    Charlotte, Vermont
    Default Composite Wood?
    I'm starting sign carving as a part of my business. I recently saw a company stating they use a "waterproof wood composite that won't absorb water and will not rot." So I'm wondering other than teak, fir and mahogany what this material might be, where you are buying it and what your experience is with its performance. Am I correct in assuming that it also might dull our cutting bits less slowly?
    Thanks.
    Rich Ahrens
    Building Character
    Charlotte, Vermont
    Sep 2011
    Tucson, AZ
    Quote Originally Posted by richahrens View Post
    Thanks.
    Maybe Color-Core HDPE? Pricey but good stuff.
    May 2014
    MA
    Take a look at HDU and PVC materials. They can be used for dimensional signs. Both materials carve great and when treated properly will last a very long time.
    Oct 2009
    Elgin Illinois
    Rich, based on your description, I would guess you may be looking at something like Miratec.
    https://www.miratectrim.com/miratec-...EALw_wcB#sizes
    From what I see, it's maximum available width is 16 inches.
    I once tried some for trim, without CNC machining it. Because it seemed like inherently flimsy material (being shredded fibers and glue), I never tested it out for CNC machining.
    Chuck
    Chuck Keysor (circa 1956)
    Columbo 5HP spindle
    Aspire 9.0, Rhino 5
    Garland Tx
    http://www.extira.com/
    http://www.talkshopbot.com/forum/sho...ghlight=extira
    I can’t recommend this product for long term signage… our experience is a couple of years at best!
    Mar 2018
    Charlotte, Vermont
    Interesting. Thanks for the replies. I'm kind of a purist but favor a wood composite by far over PVC if given a choice. I'd expect PVC to be flimsy but there are likely lots of products out there I've never encountered. I see extira is made by Jeld Wen and many of their products are at my local lumber yard. I'll ask if they can get it. With a ten year warranty it must be a decent candidate. I've never heard of HDU. I was hoping there was a simple "go to" as an industry standard!
    Rich Ahrens
    Building Character
    Charlotte, Vermont
    Garland Tx
    Rich…
    A little history may be in order…
    There was a time when the go-to material for outdoor signage was Red wood… it was a fantastic material, and still is if your customer is willing to pay!
    In an effort to be competitive and to use materials available locally, many other woods were tried… western cedar works for some applications, white oak if you maintain the finish regularly and even some exotics available in limited quantities and areas can have their use!
    It seemed like the sign makers prayers were answered when HDU came along! High Density Urethane foam became available in sizes that didn’t require glue-ups, was light weight and easy to handle and machined well! The perfect sign material… until the first hail storm!
    PVC has been around awhile… its reputation was nearly ruined by attempts to make it lighter and less expensive… the foamed PVC’s like Sintra© and others work well for interior, well supported lettering, but not at all for dimensional letters. Its interior is open cell and a completely different texture from the surface skin. Colors fade with UV exposure and it’s available in very limited thicknesses.
    Some of us have rediscovered solid type 1 mechanical grade PVC. It’s consistent in density, UV stable and readily available at plastic supply houses and sign supply dealers. It’s expensive. My tendency, lately, has been to mechanically fasten 3D PVC letters to a western cedar background. Others will fabricate the entire sign from PVC. It only comes in white or black but paints well with any paint intended for plastics. PVC solvent welds well, but plumbers glues aren’t ideal for this application… some like a PVC glue made by Gorilla.
    I’m sure my limited experience has caused me to omit some history and I welcome input by others!
    Dec 2005
    Pro Signs, Coal CIty IL
    Here's an example of HDU. Just finished painting it yesterday. I'm trying to get away from HDU, but this particular customer insisted on HDU as it is going right next to another HDU sign and he was set on keeping the same material. This one is also 106" wide, again to match the other sign, so I had to join a piece on the end. My CNC is 48x96. I spliced it at the logo on the left. Unless you know what you're looking for and look real close, it isn't noticeable, especially in the area where it will be installed.
    Sep 2012
    Blaine Mn
    This is a 4x10 foot sign I made a couple years ago- last year we had a nasty hail storm and you see the damage done- the sign was done using Duma HDU [Corafoam], except for the letter 'C' which was another brand I wanted to use up. The sign was built on an aluminum tube backbone and then a sheet of Composite alum/plastic, the white was 1" PVC. The hail pounded out the windows on the West side [where the sign is] and did 3 million dollars in my homeowners association alone. They are still fixing storm damage here. It is 12' up, too far for an oldphart, so I have not looked really closely but if it was not for the 'C' I would just repaint it.
    Just for reference. Gene
    Mar 2018
    Charlotte, Vermont
    Thanks, for this info everyone! I need to learn this stuff from veteran builders like yourselves.
    Being in New England, my intention is to make "traditional" carved signs but wood is indeed dearly priced. I was at Chatham Carved Sign on Cape Cod last week and was shocked at the prices they get for small, house numbers which I can easily make already on my ShopBot Buddy. They are the ones who say they use the composite I referenced above so it seemed to a neophyte that I should research and use the same.
    Please keep the info coming. This week I got some One Shot paint to use on my first pieces. The above specs they prime twice and put on three coats.
    Rich Ahrens
    Building Character
    Charlotte, Vermont
