Results 1 to 10 of 12
Thread: Converting Part Works File.crv to .sbp file
    Jan 2010
    Buffalo Creek Calls, Stover MO
    Default Converting Part Works File.crv to .sbp file
    I was trying to run files I created in PW V2 which have a .crv extention. The control software does not reconize them. What are the steps to convert a Park Works File into a .sbp file that the control software reconizes?
    Jan 2006
    Un-Employed Westminster, Ca
    You need to generate and save a tool path file.
    On the upper right side of the PartWorks screen is where you do this.
    You need to highlight the area of your work you are going to tool path then select the tab on the upper right of the screen.
    There you can pick what type of tool path you are going to make, select the tool, set the depth, speed, etc.
    I am sure Vectric has a video of how to do this on there site.
    Jan 2010
    I have made all the tool paths but the file extention remains .crv which the control software won't reconize. I need to figure out how to convert to .sbp file. No option to save the file in that format exists that I can find.
    Jan 2006
    Under the tab to the upper right is an icon to save.
    Have you saved it under this tab or under the save icon on the left?
    You are saving the TOOL PATH not the file (.CRV) with the save icon under this tab.
    David Marcotte Svc LLC, Cocoa Fl.
    Mike, when you save and it shows .crv
    backspace the .crv away and then add in .sbp
    I do that sometimes.
    On second thought , if something is wrong with your software this may not be the right solution for you.
    looking at partworks, are you clicking the icon
    that states "save toolpath" in the toolpath side?Have you set up the correct post processor?
    cnc routing, portland or
    Feb 2012
    pennsylvania
    Default new new new
    Hello all.
    New guy here.
    Ive tried saving all file types but I cant get part works to save as a sent file. When I "save" in the tool path area I get an "invalid argument was encountered" prompt.
    Its very frustrating as all im trying to start with is a simple circle.
    I just bought this machine if there is anyone whom might assist I would be most happy.
    Ill also contact vetric to see if they can help.
    Im not sure where to even start.
    Bill
    Have you gone to the vectric site and watched the first cut 2D video it will show you the steps to take
  1. Replies: 7
    Last Post: 11-14-2016, 01:44 PM
  2. Converting csv to sbp file
    By Ben Guengerich in forum Other
    Last Post: 08-18-2014, 11:28 PM
  3. Need help converting a .max file
    Last Post: 02-11-2010, 10:44 AM
  4. Part works file from Only saved tool paths
    By hunterland in forum PartWorks
    Last Post: 03-31-2009, 05:19 PM
  5. Converting VectorWorks dxf file
    By waynelocke in forum Archives - thru 2002
    Last Post: 12-19-2001, 09:17 PM
