Results 1 to 4 of 4
Thread: Convert file to DXF?
    Jan 2013
    Massachusetts
    Default Convert file to DXF?
    I own a shopbot cnc and purchased the Aspire software with it. When I go to save the machining file it does not contain a dxf extension choice. Can I convert one of the extensions to a dxf file?
    Sweep select the vectors you wish to Export, and then under File/Export , you'll see the .dxf option.
    Jan 2013
    Massachusetts
    Hi Scott,
    Thanks for the quick response. I hit dxf, now what do I do, nothing happened
    Angelo
    Oct 2010
    TX
    You select the vectors you want to export to a DXF, then select export function. Save. Then open in whatever other program you are needing them in ( I will assume it is a drafting file of some sort). That program may require you to IMPORT them...)
