Results 1 to 4 of 4
Thread: Restart cut on G-code line 13590
    Sep 2018
    Tooele, Utah
    Default Restart cut on G-code line 13590
    Hello,
    I have a very long cut I am doing, with just over 20,000 G-code lines. When my Shopbot Buddy cut to line 13590 my laptop computer went into sleep mode, causing my Shopbot to pause. I took my laptop out of sleep mode, and my Shopbot would not continue on, just sat there in the position it stopped at when my laptop went to sleep mode. I then restarted the program, and it took it all the way back to the beginning of the cut. How do I cause my Shopbot to jump to line 13590 in the G-Code where it left off? I don't want to watch it do an unneeded 1:45 minutes of pretend cut run time. Thanks for your help in advance! Evan
    TJ gave a tutorial on this;
    https://www.youtube.com/watch?time_c...&v=OLY1btpEHqo
    Should help you.
    Scott Plaisted
    2013 Desktop/spindle/VCP 9
    Sep 2018
    Tooele, Utah
    Thank you. I appreciate it
    cnc routing, portland or
    I just edit the file. I delete all the moves between the first one and the first jog move before were it left off.
