Results 1 to 5 of 5
Thread: Need help with settings
    Dec 2005
    Pro Signs, Coal CIty IL
    Default Need help with settings
    I have a problem. An electrical storm took out the mother board on my computer. We fixed that, reloaded the shop bot & part Wizzard software. I sent a job to the shopbot and got a message saying I'm in plazma cutting mode. I'm hoping someone can tell me where I go to switch it to router mode. If I remember right this happened once long ago, but I can't for the life of me find where to switch it back to router. Thanks for any help you can provide.
    gary
    frank Guest
    Hi Gary,
    It sound like you selected the wrong post processor in Part Wizard. Make sure that you select the ShopBot inch arc or mm arc post processor.
    Jul 2005
    Gorham Maine
    Gary, I looked thru my version of the ShopBot software 3.19 and found no reference to the Plasma cutter. I’m guessing you are using an older version of the software, perhaps DOS. If your running the windows version you might try downloading the latest version. A call to ShopBot may be in order if that does not work.
    Dec 2005
    I have a dell XP with part wizard v1.02. Where do I go to find the post processor? Thanks again.
    Dec 2005
    Thanks Frank. It's up and running as I type this. The setting defaulted to Plazma as you thought. I have some trim boards to put flutes in for a cabinet maker. This makes us both happy.
    Thanks again
    Gary
  1. What settings went wrong?
    By jim_stadtlander in forum Troubleshooting
    Last Post: 04-07-2014, 03:15 AM
  2. Plywood Settings
    By wrkwatchr in forum ShopBotter Message Board
    Last Post: 10-08-2013, 10:46 AM
  3. 3D Carving VR settings
    By woodshopcnc in forum ShopBotter Message Board
    Last Post: 05-14-2013, 05:19 PM
  4. value settings for bt 32 standard
    By msantos in forum ShopBotter Message Board
    Last Post: 09-05-2012, 04:46 AM
  5. Shopbot Settings?
    By blake_koehn in forum Archives2008
    Last Post: 12-10-2008, 06:05 PM
