"nicks" in female inlay machining
Hi all,
Today's inlay production work went a little wonky, and I am curious if anyone has any insight. You can see clearly that it was cut in two passes, which is the minor issue. The bigger issue is the strange "nicks" that were consistently in the same places.
I used VCarve Pro's female inlay toolpath like I always do. Only difference was I used a new type/brand of 1/8" downcutter. The male inlays using the same bit came out fine. And the large area clearance part of the toolpath went fine too.
Thanks for your help!
Brian
- You may not post replies
- You may not edit your posts
Forum Rules
