Results 1 to 7 of 7
Thread: Dynamic In-Motion Depth Control
    Mar 2008
    The Adventurer's Outlet, Bolton MA
    Default Dynamic In-Motion Depth Control
    Hello
    Is there anyway to jog the cutter up or down during a cut? I know you can change the speed of the cutter with the Shift <> keys. Is there something similar for cut depth?
    I am doing so fairly intricate engraving on some gun stocks and the material (or my bed) is not perfectly level and I need to keep Nudging the cutter up or down. If there was a way to do this dynamically it would be great.
    Thanks!
    Ben
    Jun 2004
    Springfield Mo
    Default layout
    Could you divide the cutting file into sections so you could run each section at a different depth as needed ?
    cnc routing, portland or
    spring loaded engraving is what you need. shopbot has one I have had ths one for many years. http://www.2linc.com/engraving.htm
    If you hit the space bar you can adjust the X Y or Z position
    adjusting the z would never make it even. I bought the spring loaded tool when I had to do these aluminum boxes and they were all slightly different hights. took care of the problem easily. .
    Mar 2008
    Default Thank you!
    I bought one this Friday and it works great. Thank you!
    no problem I never use mine anymore but it paid for its self.
