Results 1 to 4 of 4
Thread: Bit for large 3d bowl
    Jun 2017
    Glendale, WI
    Default Bit for large 3d bowl
    Hello everyone,
    I have made many, many flat bottomed trays using bowl/tray bits, and I would like to branch out and create a proper bowl/dish using thicker stock. This is new territory for me. There's no fine detail -- just a nice big oval dish cut from 2" stock.
    I can handle the basic programming in VCarve Pro 9 (thanks to Vectric's great tutorials). I would love some guidance on this:
    1. Should I use both a roughing and a finishing toolpath?
    2. Which bit(s) are ideal?
    3. Using a radiused end mill isn't a great idea, right?
    I have a 1/4" ballnose, but that would take forever for a large dish. So I am willing to invest in the right tooling to do this. I also don't mind a little extra sanding effort after machining since there's no detail to worry about.
    I have a PRS Standard 96-48 with the 2.2hp HSD spindle.
    Thanks!!
    Dec 2005
    Pro Signs, Coal CIty IL
    Judging by your description, I'd be inclined to use a 1/2" ball nose. I don't always do stuff by the book, more often I use what I already have on the shelf when I can, if it means saving a trip to the tool store.
    Jun 2017
    Glendale, WI
    Quote Originally Posted by pro70z28 View Post
    Thank you. Any opinion about cutting height? Looking at Amana tool options, there are 1.25" and 2.125" cutting height options. I guess it depends on the angle of drop as you bowl out the stock, right? Steeper angle would require a longer bit to keep the collet from interfering.
    I don't mind going to the tool store since it's usually either Amazon.com or Toolstoday.com
    Jan 2011
    gleason, wi 54435
    you should probably be looking at a core box bit rather than a ball nose since you get a deeper cut for larger bowls. I would use a .5 to a .875 diameter bit with a .5 shank for more aggressive cuts then a finish cut with the same bit but a finer stepover to reduce sanding labor. In my experience a smaller ball nose won't help much.
