Thread: alternative dust collection in high static environment
    Jun 2017
    Glendale, WI
    Default alternative dust collection in high static environment
    Hi everyone,
    My static woes continue...after weeks of problem-free operation, yesterday it was back to the same old problem while surfacing a slab.
    I'm 99.9% sure the problem happens only when running my 3HP Oneida Gorilla Pro -- which is quite powerful and moves tons of air. I have also never experienced this problem March/April - September/October.
    I am done troubleshooting and tinkering and need a "winter workaround." The idea is to get a less powerful DC, tap into existing ductwork with as short a run as possible, and run it during high static months instead of the Oneida.
    The tricky part is that the workaround DC needs to be powerful enough to collect chips, but not too powerful such that the high airflow causes the same problem.
    So....1hp wall mount, 1.5hp, or 2hp? I would rig up a cyclone separator no matter the choice; and because the CNC makes more chips than dust, I am not too worried about super fine micron filtration. At least I don't think I am.....
    The wall mount intrigues me because I could mount it high on the wall and tie into existing ducting near the ceiling instead of at the floor where you work against gravity. Seems much more efficient. I guess I could wall mount a 1.5 or 2hp motor too with some hacking.
    Thanks for your thoughts.
    Brian
    Jul 2005
    Brookline, New Hampshire
    Can you run a humidifier in your shop? Perhaps put water in a spray gun?
    Paul Z
    Jun 2017
    Glendale, WI
    Quote Originally Posted by paul_z View Post
    Paul Z
    My experience in the winter here in Wisconsin is that the air gets so dry that it will hold very little moisture. So when I run a humidifier, I end up putting much more moisture onto the ground and onto surfaces than into the air.
