Results 1 to 5 of 5
Thread: Loss of Y then Y&Z
    Jan 2013
    Massachusetts
    Default Loss of Y then Y&Z
    Ok this will be a hard one to explain.
    Here is the scaled down attempt
    Was cutting a large 3d file (about 5hrs) with .0321 ball nose bit, speeds 5,3...
    1) Lost Y position intermittently (see photo below)
    2) Checked file and Y positions were fine
    3) Called SB support
    4) Switched Y and Z red,white, green, black wires in control panel and switched values input driver definition for Y and Z--no luck
    5) Switched Y and Z motors and all ran fine with no problems
    7) Next day went to cut a simple square pocket lost location on both Y and Z axis--Z off about 3/16" and Y off by about 1.5", X was fine
    8) Tried different laptop
    Tried SB support this morning and they have not gotten back to me yet.
    Tried a different computer--no luck
    Help. Christmas business is suffering. Any other possibilities or suggestions?
    Angelo
    Apr 2019
    London
    im totally loss
    teen age girls haircuts for boys!!!!!
    An intermittent loss like that can be due to a grounding issue. If your tool is grounded check all the connections and make sure they haven't come loose. If it isn't, then you need to do so.
    A "grounding" search will lead to plenty of info in how.
    Please try the following:
    1) Run VR command. At bottom of fill-in sheet, click on Reset.
    2) Slow things down to 2,1 and see if it still loses steps/position.
    What machine are you running? (Desktop, Buddy, Gantry tool - assuming this is not an Alpha)
    Just noticed-the original post was from December 2018.
    Hopefully he got it solved.
