Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Complete Shutdown
    I'm wondering if the control box is sending something back to the PC telling the control software to shut down? Seems, with all the troubleshooting you've done, that is the only thing I can think of. See if ShopBot tech support can help to determine if the control box could do this.
    Dec 2011
    Piedmont, SD
    x2 what Don said. Call shopbot.
    Meanwhile, congratulations, you've eliminated the PC from the list of culprits.
    Another note: I have a laptop that now shuts off completely out of the blue. Finally realized what's going on - I was giving it a static shock, which kills it instantaneously. Now have a raw ground wire hanging on the side so this doesn't happen during this dry time of the year. Pretty disgusting to be faced with such a stupid problem on a $1,200 laptop, but it is what it is.
    Naturally, I can't help but think of this as it relates to your problem. Due to number of machines you mentioned, I have to believe you've consistently grounded them all, but take a close look at the grounding to be sure nothing's going on there or has been inadvertently altered.
    Please, do keep us all posted. Of all the bizzarr-o stuff that can happen, I've not heard of your exact issue in the several years I've participated in this forum.
    Good luck,
    Jeff
    Again did you reload the firmware
    Nov 2011
    Akron, OH
    I really appreciate all the feedback. Thank you.
    Grounding looks to be the next step. I haven't had this issue in the past so I figured it was grounded properly all these years, but maybe I need to take a closer look. I see that grounding the frame to the 120v is the proper way. Is there an optimal point on the frame to ground from? Close to the cutter? Motors?
    We have reloaded the software and firmware many times, but I will give it another go. Doesn't hurt anything.
    Another potential I saw on Shopbot's website is "Check if the excess motor cables are looped up inside the control box.". They aren't but I do have excess motor cable looped under the table. Is this a concern for proper communication?
    Jan 2008
    One more place to check that I haven't seen anyone state is to swap out the cables. I have a heck of a time getting good cables here locally. Most of the time it is related to USB issues but there are lots of cables to run one of these machines. I wish you well, intermittent issues are the absolute worst! Russ
    AKA: Da Train Guy
  6. #16
    Do a UT in the command line, and read carefully....then give us the "Packet ET" time...give us a better idea of comm speed?
    USB cable next to a major power spindle cable...COULD do it(Lucky it's virtually impossible on Desktop
    DID have problems my first week as every cable was anally coiled and nested Perfectly
    Messed it up and separated and was back in business.
    Scott Plaisted
    2013 Desktop/spindle/VCP 9
    Nov 2011
    Akron, OH
    I have swapped out the usb cable. Should I try any other cables?
  8. #18
    Marietta GA
    Quote Originally Posted by Shayne Jenkins View Post
    After it "crashes" check the windows event viewer to see if it's logging any errors?
  9. #19
    Nov 2011
    Akron, OH
    Packet ET is between 15 and 19.
    I do not see any error logs in the event viewer.
  10. #20
    So comm is OK. Good....But the "Intermittents" are the worse to diagnose!
    Had an HDMI that was "Jiggly" on the monitor and tried 3 different cords...now elastic banded and duct taped...2 years no shutdown(fingers crossed).
    Keep a log of what you've tried and done for Support.
    Sorry I can't help
    Scott Plaisted
