Thread: Enhancement of sign with appropriate size post.
    Norman, Ok
    Default Enhancement of sign with appropriate size post.
    Sign post examples we often we use. The material is rough cedar. It's so easy to work with, lasts a long time and not too expensive.
    By using a minimum of 2" thickness there is seldom any checking. Because the material is always damp it's necessary, when painting, to lay down a oil based barrier like Kils or Ronan block-out white in order to capture bleed through.
    Even plain panels look better with larger posts.
    Joe
    www.normansignco.com
    Jan 2011
    gleason, wi 54435
    Nice posts Joe. Do you run screws through the cedar and into the 4 x 4's or leave it loose?
    Norman, Ok
    Bob,
    To save time I like using standard decking screws.
    Wish we had more sign artist still posting.
    Keep up the good work.
    Joe
