Results 1 to 8 of 8
Thread: Engraving Acrylic
    Nov 2011
    St. Joseph Mi. 49022
    Unhappy Engraving Acrylic
    I do a lot of lighted acrylic signs. I'm using a carbide 45 or 60 degree cutters. I cut between .o15 to .o35 deep. I have tried spindle speeds of 10,000 to 14,000 RPM, and feed rate of .3 per second. I installed a mister on the shopbot and run water and a little bit of Johnson baby oil in it. This has helped 90 percent to stop the chips from sticking in the groves. But still not 100 percent. I then have to try and scrape the rest out by hand or with air hose. If I'm not careful I will scratch the acrylic. Not good. Any ideas? thanks
    I'm guessing the basic issue here is insufficient heat removal. Either increase the feed rates or decrease the RPM's to increase the heat rejection. The chips are sticking because they are partially melted.
    PRS Alpha 96x60x12
    Mar 2005
    As coryatjohn noted above your not hitting the chipload with your feed and speed.
    for acrylic, 48ipm 8000rpm for small letters (.5), 60ipm 10000 for larger
    then you don't say what tooling your using, not all v-bits are suited to cut plastics so your tool selection maybe a hindrance to your cut as well.
    Gary
    Custom CNC Tooling/Onsrud Distributor
    Are you using cast or extruded acrylic that make a big difference
    Nov 2011
    Which is better. I can get both. Thanks
    Nov 2011
    Mission B.C.
    Quote Originally Posted by badboys cnc View Post
    Cast acrylic is best.
    Rik
    Cast is also usually more expensive... I don't think there's much 1/4" cast acrylic around.
    PRS Alpha 96x60x12
    I use a lot of 1/4 cast acrylic many different colors Most I cut on my laser but I do some on the bot. Easy to get cast if you order from a supplier
