Results 1 to 10 of 13
Thread: Ideas on making this barnwood sign
    cnc routing, portland or
    Default Ideas on making this barnwood sign
    I have a customer that wants me to make the faces for this sign. this is a rendering. his customer was a barnwood look and is willing to maintain it.
    but gluing barnwood onto say a piece of dibond is not a great idea. I was thinking of planing the boards down to 1/8" to make it a veneer and epoxy it onto a piece of 1/4" dibond then coat the face in epoxy then use a uv protection on that. I would also seal the edges after I cut through the face.
    does thsi sound like a good idea? would I need to laminate the backside too?
    I would do it with some nice Western Red Cedar planks.
    I would use Sikkens for the finish so he would only have to put a new coat on every couple years with no prep beyond cleaning needed.
    Epoxy on an outdoor sign face, even with a UV poly over it, is asking for trouble IMHO.
    Of course, you could also texture sign foam and faux paint it with exterior latex.
    Nov 2016
    New Mexico
    IMHO...
    We would use a sheet of Maple plywood, 3/4" thick. That would be two sheets for this project.
    1. Design the planks and cut them into the maple (to give the illusion of glued-up planks)
    2. Spray or brush the finished sign with lamp black stain.
    3. Sand off the lamp black with 220 grit (after it is dry).
    4. Spray or brush with General Finishes Pewter Die.
    5. Poly for a finish coat.
    Here we have designed and cut a wine barrel using Maple playwood. You could design and cut the planks. Actually, you can get wood plank artwork from vectorstock.com.
    Dave B
    New Mexico
    I had thought of that.I can't do the painting though my paint skills are nil. but I will throw both at him.
    Quote Originally Posted by woodshop View Post
    IMHO...
    Feb 2004
    Rogers, Arkansas
    I would glue up the wood, pocket the letter outline into the wood 1/4" or so, and apply letters cut from White PVC, signfoam, or even dibond so they stood slightly proud of the background. Like Dave I'd use a wood other than barnwood and finish with sikkens. Makes finishing easy - finish the wood separately, spray the letters white, then combine once all are finished.
    Ken Zey
    Rogers, AR
    www.CedarSlabSigns.com
    www.lookoutmercantile.com
    www.digitalmillwork.com
    6x12 PRS alpha
    If it's going to be for exterior display, you won't want to use maple. You know the customer won't always keep up with the maintenance schedule and maple will rot/spalt easily. White oak would be better than maple if going the solid wood route and exterior use.
    Nice looking barrel design Woodshop!
    Norman, Ok
    Congratulations on a neat little project.
    We love this kind of work and it can be the fastest and easy if you go natural. The customer suggested barn-wood. That means the sign should look weathered, having some personality. It's a mistake to attempt to take fresh wood and apply aging techniques unless absolutely necessary.
    A Local fence company may have plenty of weathered fence material left over from replacements. They would probably be happy for you to take off his hands. Yes it will have lots of cracks and knots from mother nature. Although you can glue these in place with E600 to MDO, there wouldn't be anything wrong with a few nails on the front side. I'd antique them and even bend a few over.
    Like Ken suggests, light pocketing for 1/2" PVC would look good.
    Painting: If you wanted to you leave it natural with a little clear coat would look good but keep in mind any top coat should be a little darker around the sides, edges and corners. If you're really serious, a thin coat of Pitch would look great. It's got to be seriously thinned down. This is most often used by the framing community over 23k gold.
    I love Pitch.
    Joe
    www.normansignco.com
    Norman, Ok
    Steve,
    How what did you decide to use for the materials on this sign?
    Would you please send a photo.
    Joe
    my customer has been dragging his feet. but we were going to use some of this flooring from home depot. but another sign customer told me about precision board with a wood grain texture pre painted.
    So when I retired from active cabinetry making a guy I had bought from locally took over my space.
    Why would I post that here?
    Check out his site: https://www.drvawood.com/
    New solid alder boards finished in water based and distressed.
    Product looks great in person but note that like genuine old planks is not dead flat like flooring.
    Grain pattern is quite distinct.
