Results 1 to 9 of 9
Thread: fan for yaskawa v7-4x fan vfd?
    cnc routing, portland or
    Default fan for yaskawa v7-4x fan vfd?
    I have noticed the fan on mine is louder. hey only 12 years old so no complaints.
    Nov 2012
    Lancashire, UK
    Default Manual error displays
    Dear Steve
    You can find the manual online..
    https://www.yaskawa.com/delegate/get...e=TM.V7.01.pdf
    Table 6.2 shows the Fault Displays..
    Sincerely
    Martin
    ya found the manual but no fans in the US. I found the fan pops out without taking it apart.so I will try cleaning it.
    Usually the plastic grill under the fan vibrates...
    All those fans are standard sizes. Check the voltage probably 24v. Measure the bolt pattern and thickness. Then find another generic one.
    ya I will take it off when I am done today and clean everything. hey its 12 years old with lots of dust running through it it has lasted well.
    well it is a oddball 60mm x25mm 24v but 3 wire plenty of two wire ones but hard to find all those
    Apr 1999
    Rock Hill SC
    It is probably a DC fan and so the extra wire is most likely a ground wire. Use an ohm meter and you can probably figure out what is what pretty quick. The pos and neg will have a resistance as will the pos and ground. ground and neg should likely have no resistance. Green wire is commonly used for ground.
    it is dc 24v but the extra wire is for speed control.
    Nov 2012
    Lancashire, UK
    Default UK Farnell or US Newark
    Dear Steve
    Farnell have some fans and have US stockist - Newark I think.. If you can find one to fit!
    https://uk.farnell.com/w/c/cooling-t...nal-depth=25mm
    Sincerely
    Martin
    PS
    Check out this similar post on spindle fans
    http://www.talkshopbot.com/forum/sho...495#post201495
