Results 1 to 4 of 4
Thread: Colombo spindle with delta vfd not shutting off after cut
    Apr 2015
    Lacrosse WI
    Default Colombo spindle with delta vfd not shutting off after cut
    I have issues with the spindles shutting off after it is done cutting a file. I have 2 Colombo spindles with delta vfds. I pushed the mode button on the spindle and it goes to a different number that is almost like a countdown from the rpm I had it set at to run. It will eventually shutdown after about 10 minutes or so when the so called countdown from let's say 10000 is nearing 0. When the number is down to around 500 or so I believe I can stop the spindle with my hand I just dont really want to grab a hold of it for certain reasons. This does not happen everytime though. Sometimes it shuts down normally. Any help would be great
    Make sure your parameters on the VFD are set correctly. Have a look here on page 47 of the PRT Assembly Manual and here in the VFD-B manual.
    Download each and file them away for the future.
    Apr 2015
    Lacrosse WI
    I just cut out about 20 sheets of plywood for cabinet parts using ecabinets and the spindle shutoff each time like it should. Used vcarve and it would not shutdown
    , Richmond Tx
    Need to either edit the post processor of vcarve, or choose a different one. The spindle off command must not be in the one you are using. Look into the ecabinets ending comments and it will show what command turns off your spindle. Add that command to the post processor in vcarve you are using
    Kenneth
