I have just received 2.2kw Chinese spindle kit which consists of a Huan Yang 2.2 kw VFD, 220volt single phase in and 3 phase out., a small submersible pump and a 2.2 kw spindle. My problem is the spindle is clearly stamped 110volts. I am not aware that 110 3 phase is even possible. Is there any way to alter the output of the VFD to accommodate 110volt spindle or does the VFD auto detect the correct output voltage. I know that the voltage varies with the frequency but do not know if the 110 spindle is even usable. Don't want to hook it up and have a puff of smoke test come out positive. Any thoughts on this?
