Results 1 to 5 of 5
Thread: A-axis Zeroing Routine
    May 2011
    Tupelo, MS
    Default A-axis Zeroing Routine
    The mother board on my computer crashed. I program in Aspire and had all my files backed-up except for two which had been created in the Shopbot software. 1) the routine to surface the spoil board (which I can recreate no problem in Aspire) and 2) the routine to zero the A-axis router using the zeroing plate.
    Does anyone have any suggestions or maybe a routine they already have created which they would be willing to share?
    Garland Tx
    Likely you have it already somewhere in the sb3 install files…
    I found “AZero” under C:\ sbparts\ .
    Let me know if you don’t find it… I’ll send you a copy.
    The surface is under tools table surface
    May 2011
    Tupelo, MS
    Found it THANK YOU.
    May 2011
    Tupelo, MS
    Thank you. I have everything up and running again now.
