Thread: By default, the Z axis rises to 1" when Stop is pressed
    Feb 2018
    Default By default, the Z axis rises to 1" when Stop is pressed
    Unfortunately, I don't actually have that much headroom on this particular project, so it triggers a fault, and I can't resume smoothly. Where do I change that 1" value to something lower, like .25"? It doesn't seem to be in any of the places I looked for it.
    Type VC in command line (Values Cutter) change Safe-Z to whatever you want(I JUST finished a project that needed .01")
    ALSO make sure in the Vectric file Safe Z1 and 2, AND the HOME position are set accordingly.
    Scott P.
    2013 Desktop/spindle/VCP 9
    Feb 2018
    Thanks, Scott - there had to be a way!
