Thread: Two spindle offset issue
    Wild Atlantic Way
    Default Two spindle offset issue
    l have a PRS Alpha with Two spindles, the offset between them is 160.00mm, l have the offset in my variables set as -160.00mm.
    When l run a file using the head2 post it moves 160.0mm and ignores
    the minus.
    Does anyone have an idea what is causing this issue, i’m using control version 3.6.44, prior to moving workshop it worked fine.
    Many thanks
    Paul
    Garland Tx
    Benchmark…
    I’m curious why you have a negative distance between your two spindles?
    Feb 2013
    River Fall WI
    How did you get your offset? Did you go through the setup routine or just add it in my variables?
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
