Results 1 to 4 of 4
Thread: Shuttering on manual move
    Mar 2007
    Ann Arbor Mi
    Default Shuttering on manual move
    I owned a PRT for years and recently upgraded to a used PRS. I am using the control computer that the guy I bought it from used. When I set it up, I downloaded the latest control software and firmware update. When I was setting it up everything moved smooth. Here's my problem. Now, while in "K", when I try to move in any direction with the arrow keys, it shutters, jumps and sounds like everything is coming apart. If I type in a location in and hit "go", it moves to the position smoothly. It also cuts smooth. This only happens when I move it manually, either in "K" or just the arrow keys on the computer?? Any ideas or direction?
    Thanks, Terry
    Reinstall the firmware via UI. Then do a UR and be sure to pick the right machine configuration.
    Mar 2007
    Ann Arbor Mi
    Thanks Brady. I tried that and it didn't help. My move speed is set at 4. If I lower it to 3, it moves smooth. That's a work around but very slow and I don't care much for work around's. One thing I noticed too is that it's losing it's location, almost like the motor is jumping teeth but the motors are up tight? Not sure where to go next??
    Jun 2018
    Kingston, OK.
    I have a PRS and it dose the same thing after i have been running it all day dosn't do it in the morning
    May Z Axes just started doing same thing
