Results 1 to 6 of 6
Thread: How do I add a slope to a 2d part? Video tutorial?
    Apr 2004
    Pearl MS
    Default How do I add a slope to a 2d part? Video tutorial?
    I have a simple 2d file I need to add a slope to.
    1. Not sure if this is 2.5d or 3d.
    2. Can someone point me to a training video on this? I have V-carve pro 8.5.
    Thanks.
    Jimmy Walker.
    Try searching Google for Aspire rail sweep. You can do some pretty impressive things with that feature.
    PRS Alpha 96x60x12
    With VCP5, try playing around with the fluting toolpath strategy.
    "He who would trade liberty for some temporary security, deserves neither liberty nor security" - Benjamin Franklin
    "Make yourself sheep and the wolves will eat you" - Benjamin Franklin
    With VCP8.5....+1 for Fluting toolpath(but Moulding toolpath maybe).
    Just a couple pics to get you started.
    Be aware Fluting toolpath uses the center of whatever bit you use, so adjust for radius of bit.
    Linear array gap..think of it as stepover on a 3D....kind of a compromise,as if you go to wide there will be scalloping on top edge from Radius of the bit.
    This is just down and dirty example....usually I do the first line as a separate Fluting toolpath with normal pass depth settings.
    Then pick them all with max depth....as you're only cutting the stepover.
    Very versatile toolpath with both Copy Array and Circular Array.
    Hope this helps.
    Oops..first pic should be Y gap of .03" and shifted over -X by radius of bit +
    2013 Desktop/spindle/VCP 10
    Apr 2004
    Pearl MS
    Thanks guys!!
    Your help is always greatly appreciated!!!
    One more trick with the fluting toolpath, to go with ScottP's first pass depth settings, is to change the start point of the second line and then do your array. That way, when toolpathed to use start points, it will alternate back and forth instead of retracting and going back to the beginning of each line. Need to use a small or zero clearance gap then too.
