Results 1 to 10 of 11
Thread: Inlay Cutting Boards
    Aug 2012
    Davenport Iowa
    Default Inlay Cutting Boards
    Has anyone made any inlay cutting boards? My concern is making them so food won't get into the board. Any pictures?
    Hey Ken,
    I've made a few, just make the inlay tight and glue it well with something like Titebond II or III and a good soak in mineral oil. Use the better types of closed or tight grain woods like hard maple, walnut, cherry, beech, white oak, etc. End grain glued up cutting boards with end grain inlay pieces work great in part because cutting the pocket and the inlay Cuts really nice with a sharp upcut bit. Another method is to cut the board apart in a curve shape with a 0.375" bit and then rip contrasting thin strips the same thickness and then glue back together. Cut it again and add another stripe, and again...
    Check out this guy's boards, beautiful work! https://m.youtube.com/user/mtmwood
    Not inlay, but here's a tumbling block one I did several years ago.
    Feb 2013
    River Fall WI
    Talk about a rabbit hole...
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    Ken…
    Here’s the inlay I do… the handmade feature strip is cut off a “master” block at about 1/8” thick. I glue it in a saw-cut groove with Tight Bond III. Cutting boards with a little bit of bling sell much faster even with a modest up charge!
    Mar 2017
    Nice touch, I agree about different touches on cutting boards. I like to personalize them.
    Epoxy inlays work well.
    Those cutting boards are so nice that I'd have to put a HDPE board on top to cut anything. It would cause me physical pain to mar it up with a knife.
    PRS Alpha 96x60x12
    Oct 2013
    3rd rock
    Quote Originally Posted by Jerry Carney View Post
    Be cautious using resins. They release toxins, and cutting into the resin can cause small pieces to end up in food. There are several FDA approved resins, and many resins with zero chemicals/natural. The cost is a bit more, but the piece of mind is worth it. Just my $.02.
    May 2011
    ny
    I do them on occasion these were done for a garlic festival, inlays were 1/4 thick glued in with west system epoxy. Inlays were sugar maple and white oak. Board is sapele
    Jan 2008
    That link to the videos is very enlightening. I don't do much in the of craft work, lot's of models, and signs, but nothing like what you folks do. Very cool stuff! Russ
    AKA: Da Train Guy
    +1 on the "Very cool stuff"
    (the Rabbit Hole made my 2 brain cells Hurt!)
    2013 Desktop/spindle/VCP 10
