I have decided to sell my Roland picza Pix-30 3D scanner. Unit is in good working order and comes with an older laptop to run it.
Great for scanning objects into a 3D fiile for carving. Approximately 8" x 12" scanning area. Contact me if you have any questions.
It is listed on Ebay: https://www.ebay.com/itm/133360408668
From the manufacturer:
The PIX-30 can scan objects as large as 304.8 mm (width, X axis) x 203.2 mm(depth, Y axis) x 60.5mm (height, Z axis). For additional height, an object that sizes up to 130 mm (PIX-30) or 70 mm(PIX-4) can be set and the top 60.5 mm part of the object can be scanned. PICZA's high performance enables a scanning pitch of 0.025 mm (Z axis) and 0.05 mm to 5 mm (X axis and Y axis). Due to precision Piezo technology,PICZA scans a wide range of objects including soft objects like clay and fruit etc. that conventional contact scanners are very difficult to scan. PICZA can even scan glass, impossible using optical scanners because the light beams pass through the glass.
