Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Dust shoe pattern
    Dec 2011
    Piedmont, SD
    Default Add LEDs to Kent Dust Shoe
    Funny you should mention lighting up a Kent dust shoe...
    I finally got around to doing so a few weeks back. Had leftover 24V LED tape cutoffs from a kitchen job. Tapped into the 24V fan motor power and hot glued a couple 1.5" cutoffs to the top of the Kent shoe. Based on the use of scraps and little time invested, I feel it's worth the convenience during tool changes, inspecting intricate work in progress, or simply easing visual verification that the bit is in fact spinning before commencing running a part file.
    (Hey - it gets pretty loud between dust collector, vac hold-down motors, plus earplug layer for audio confirmation to reach my ears...)
    I recommend giving it a try.
    I've also seen others with LED's on the gantry for visual alert that machine is operating, which I also find very appealing.
    This was uber-simple, very effective, and actually kind of cool...
    Jeff
    I like it!
    Like it Jeff!
    Jun 2010
    Edmonton, Alberta, Canada
    Nice! I never thought of the lights as a visual safety indicator, probably because I have the much louder Porter Cable routers. I also have dual Z axis setup so I can't get the Kent show installed like you did (at least based on the way I'm picturing that you probably did it).
    Dec 2017
    Frankenmuth, MI
    For those that have built their own dust shoe, where is a good source for the brush?
  6. #16
    brush.com
    check out the strip brushes...
