Results 1 to 10 of 10
Thread: Physical Pause Button?
    Feb 2019
    Default Physical Pause Button?
    I'm looking to add a physical "Pause" button beside the shopbot for small oops.
    Is there any wire input left on the current PRSalpha to make into a physical pause button?
    Also, does anyone know if hitting the emergency button cut power to the encoder? aka, will shopbot lost position after the emergency button is hit?
    Thanks!
    Jason
    Try pressing the spacebar. That's the pause button.
    Feb 2019
    Quote Originally Posted by coryatjohn View Post
    Thanks but I already know that.
    The set up we have in the makerspace is a bit awkward; the computer is inside the inner corner of the CNC room (we load material from the back of the shopbot).
    I want to add a separate pause button right outside the CNC room's window, so users can watch safely outside and pause the machine before entering to fix anything.
    Dec 2005
    Pro Signs, Coal CIty IL
    My ShopBot, old PRT96, came with a pause button. It's still connected to the control board, but It's been years since I've rolled up the cord and hung it on the wall. If I remember right it's a good 15' to 20' long. Back when I used the next room to do signs (moved the sign shop since) my plan was to run that remote into the next room for a similar reason to what you mentioned. Then use the space bar when I'm in the room. To be honest, it's been years since I've used it. I don't remember if it just pauses the job or it kills it requiring a restart. Don't know if that helps.
    I don't think that will work when you are running a file
    It's just a fancy keyboard with a limited button set.
    Sep 2012
    Blaine Mn
    You can program it to do anything there is a keyboard shortcut for.
    Dec 2005
    Just a question. Don't mean to hijack, but it is somewhat in keeping with the OP's question. Is there such a thing as a plug in wifi module or something similar that would allow the CNC to be run by a phone app? My machine is ancient by CNC standards (PRT96), but it does have an upgraded control board.
    If so, that might be an answer to the OP's dilemma. I know I could use a set up like that.
    NOT sure if this is updated and current what with phone tech....but????
    http://www.talkshopbot.com/forum/sho...hlight=coogara
