Results 1 to 10 of 12
Thread: I'm bored...
    Oct 2013
    3rd rock
    Default I'm bored...
    We have a lot of car cruise-ins around my area...probably not so much this year, but I thought I would practice modeling some plaques.
    Jun 2007
    Hampton Roads, VA
    Looks like a good start. It's digital so lets play. I'd pull the cars apart maybe tip them down a bit to match the oval slope and give an aggressive stance. Make them a little smaller. Move the diamond center and larger put the checkered flags on the diamond maybe half height of the diamond. I would move the letters to the top and find a banner ribbon for the bottom or create a place for a brass nameplate. The reasons for the letter changes and centering the diamond are branding the Diamond Shine sponsor. The negative (un-3d carved) areas will show off the wood.
    Thanks, that was a nice distraction. Just my 2cents
    here is my last commission:
    Oct 2013
    3rd rock
    [QUOTE=khaos;206708]Looks like a good start. It's digital so lets play. I'd pull the cars apart maybe tip them down a bit to match the oval slope and give an aggressive stance. Make them a little smaller. Move the diamond center and larger put the checkered flags on the diamond maybe half height of the diamond. I would move the letters to the top and find a banner ribbon for the bottom or create a place for a brass nameplate. The reasons for the letter changes and centering the diamond are branding the Diamond Shine sponsor. The negative (un-3d carved) areas will show off the wood.
    I appreciate your input. I've just started down the 3D path, and compiling reliefs.
    I'm just messing with the modeling, and this isn't an actual brand, or for any particular event.
    I cut the door from the other post, yesterday. I did it out of Poplar (the only thing I had on hand), and I'm not pleased with the outcome.
    However, it will still be used for the project, since it will just go in the flower garden as decoration.
    Feb 2010
    SOUTH CENTRAL COLORADO
    Whatever you do, do not get into 3-d. It is addicting. 99% of what i do involves 3-d.
    May 2009
    Philadelphia PA
    Quote Originally Posted by cowboy1296 View Post
    Now you tell me...LOL
    Michael
    Feb 2010
    Yeah Michael of all people you should know.
    Oct 2013
    3rd rock
    I messed with this one for about 20 minutes.
    Feb 2010
    Default i dont need to cut non stop
    Even with the lock down, since i had a good supply of wood and ups is still running i am still able to get some things out. both of these either were or are a work in progress.
    I'm Liking that last one 8Ball!
    Been playing with a similar thought model today.
    NOT mine...3dwav.org
    Feb 2010
    scott i still use amana ball nose bits, i know that you use a different kind of bit. tell me again what you use for your finishing tool path?
