calling on the probe experts
I am looking to use the Shopbot probe to calculate the 2D profile of an existing turned part. I won't need to rotate the indexer at all. All that I need to do is probe one side of the turning in order to get a 2D profile of the shape. From that point, I know how to import that 2D polyline into Aspire and do a two rail sweep in order to re-create the part on my indexer.
I don't currently have a probe and have never used one.
I see two scenarios that could work, my indexer is mounted along the Y-axis:
1) Align my Shopbot's x-axis on the centerline of the part (vertically). Then probe the top of the part moving in Y and Z only. From reading the online info about the Shopbot indexer software, I think that the software won't handle the Z moves, unless I can swap the Z for the X axis.
2)Align my Shopbot's y-axis on the centerline of the part (horizontally). Then probe the side of the part moving in X and Y only. I think this will work if I have clearance between the part and my table.
For those that use their probe, does this sound possible?
PRT Alpha with 7.2 upgrade, indexer, and PC router
