Results 1 to 8 of 8
Thread: Total runtime
    Jun 2019
    Default Total runtime
    Is there a file within the SB control software that records the total machine runtime?
    Dec 2008
    Diamond Lake, WA
    There is a log file that has all this info in it. I believe it's in the \\Shopbot subdirectory.
    Don
    www.dlwoodworks.com
    Jun 2019
    Quote Originally Posted by dlcw View Post
    I see the log files for the individual jobs however, haven’t found one for the TOTAL runtime of the machine
    I dig a little deeper when I get back into the shop
    Thanks for the info
    I very possibly could be wrong,
    But I believe you would have had to have the "Shopbot Odometer" installed.....It can be downloaded here under Shopbot Labs;
    https://www.shopbottools.com/support/software
    2013 Desktop/spindle/VCP 10
    Jun 2019
    Thanks Scott. I downloaded the file and will attempt o load it tomorrow
    Oct 2000
    Willis Wharf, VA
    All the Odometer does is to make the data from the System Log file a little easier to read by simplifying the amount of info that's displayed.
    For the Odometer to work, in The VD (Values Display) menu make sure that you have "Write System Log" set to 1-Write. I tend to keep "Write Part File Log" set to 0-Don't Write to keep from having a log file for every file i run, but that's a personal preference
    Jun 2019
    Quote Originally Posted by bill.young View Post
    Hummmm, thanks for the info Bill. I originally had the file set to write however, soon learned I didn’t want all the logs so disabled it. That being said I think I’ll install an external hour meter.
    Thanks guys for all your input.
    Ron
    Oct 2000
    Willis Wharf, VA
    Hey Ron,
    Remember that there are two type of log files. The Part File Log option writes a separate log file for each file you run...it's the one that write all the extra files...but the System Log option only write one file that it appends whenever any file is run.
    The Odometer reads that System Log and ignores anything that's run in Preview mode so only counts files that are run in Cut mode. It keeps a running tally and also lets you export as a spreadsheet if you want to do something interesting with the data.
    If you want to keep track of how long your ShopBot is powered on though, an hour meter connected to the power is the best solution. The odometer just counts when a file is cutting
