Results 1 to 6 of 6
Thread: Need some help with Lenovo laptop.
Hybrid View
    Nov 2013
    Morganton, NC
    Default Need some help with Lenovo laptop.
    I have a hand me down lenovo laptop that I would like to use as a backup. Its running windows 10. It will not connect to the controller. Anyone know why?
    have you loaded drivers? Also I have a Win10 machine that I have to plug in to the bot and restart every time to get it to talk to the controller.
    Jun 2004
    Springfield Mo
    Default Shopbot link
    This link might be handy... covers a lot of areas.
    https://www.youtube.com/watch?v=fPWe-PFofkA
    Aug 2012
    Victoriaville, QC, Canada
    I have a lenovo laptop that I used to use to control the shopbot without any kind of problem. Right now, I have a lenovo desktop hooked up to the shopbot and it's working perfectly.
    If I understand correctly, your computer is second hand... When you got it, was there a bunch of applications installed on it or was it clean (fresh windows install) ??
    Of course a clean install would give you less chances of problems.
    I understand that Windows 10 has a procedure that you can use to perform a clean re-install of the itself. It does remove all user files and all applications that doesn't come with Windows... I would suggest doing this procedure and restart fresh. Note that I did not run this procedure myself.
    On my one laptop I just had to reload the firmware for the shopbot to see the drivers.
    Dec 2020
    You need to install the drivers you received with the controller or take it to the service center they will fix it for you
