Thread: Pocketing operation tool set up
    Oct 2009
    , rochester ny
    Default Pocketing operation tool set up
    Hi all,
    I have a job where I need to do a narrow (3/16") grove cut in a cabinet side for a striker plate. My usual pocketing tool is a .25" M.C. bit, which will be to big. I added a .125" spiral bit in the tooling, after the .25" M.C. bit in the tooling operation set up and checked the 'Rout/Dado' type of operation it's to perform.
    No dice. Part gets nested and the operation throws an error warning saying the pocket can't get performed....
    Seems like it should be straight forward tool set up but there must be something I'm missing? Haven't found anything in the help manual that would clear this up and was wondering if anyone else has had this pocketing issue and knows how to set up a tool to make it run the pocket?
    Tim
    Oct 2009
    , rochester ny
    Here's how I've set up the .125" bit..
    Oct 2009
    , rochester ny
