Results 1 to 9 of 9
Thread: Engraving Material
    Jul 2018
    Default Engraving Material
    We are new to the Shopbot CNC world and are trying to route Rowmark engraving material. The results are not acceptable due to tooling marks. We are using an 1/8" end mill with slow feed rates ( 20 inches per min), moderate router speeds ( 14,000 rpm) and cutting depth of .02. The tooling marks are not everywhere but appear on certain letters inconsistently.
    Any thoughts on how to achieve a cleaner end product?
    Jun 2004
    Springfield Mo
    Default photo ?
    Do you have a photo?
    With plastic, the bit manufacturer might be your best bet on information on the feeds & speeds.
    Does it clean up if you run the file twice ? / maybe add few 1000ths on the second pass ?
    Jan 2008
    I do a ton of little name plates / badges, etc. I have never used an end mill, always some form of ENGRAVING bit. Russ
    AKA: Da Train Guy
    Jul 2018
    Thanks for your advice. I purchased an engraving bit and will let you know how that works. i appreciate the guidance.
    Jan 2008
    I should also add for larger plaques / signs if there is going to be a large 'pocket' area I use two tool paths. First I use the 'tapered' engrave bit to 'outline' the pocket, and then you can use an end mill to do the pocket. This is because you have already relieved the edge of the pocket. I hope that makes sense! Russ
    AKA: Da Train Guy
    TJ oftened mentioned these bits designed for color core with high praise;
    https://www.centuriontools.com/collections/engraving
    Never personally used them, just thought I'd mention them.
    2013 Desktop/spindle/VCP 10
    Jan 2008
    Yep. that's the beastie's! Russ
    AKA: Da Train Guy
    Sep 2012
    Blaine Mn
    I use a lot of Gemini Duets material and they have mostly material for laser engraving which I use but also have different material for machine engraving. Not sure the difference but there must be?
    Mar 2008
    Radford VA
    I have engraved with the Rowmark. You need to triple your feed to 60ips. If you have large areas to clear, try using one of the flat bottom endmills from Centurion. https://www.centuriontools.com/colle.../downshear-fem
