Thread: Forgetting Tool in Spindle
    Oct 2011
    Pittsburgh
    Default Forgetting Tool in Spindle
    Hello,
    My shop bot started forgetting it has a tool in the spindle outta the blue. For example: after I run a part file I cannot simply hit replay or it will try and pick up the same tool already in the spindle. The same goes for multi tool part files. If I have say tool #1 set to cut the first tool path then tool #2 set to cut the next - it will forget it has tool #1 in the spindle and try to pick up tool #2.
    My first instinct is that it is in the programming but also wondering if it is somewhere along the line of hardware because I haven’t touched any of the programming. I’m not well versed in either so any and all help would be much appreciated.
    Thank you,
    Cody
    PRS Alpha - 5hp HSD ATC Spindle
    -best part of life is living it-
    Jun 2015
    Durham NC
    Cody,
    Send us an email at support@shopbottools.com with the cut file you are running and we can help.
    Best Regards,
    Tom
    Technical Support
    ShopBot Tools, Inc
