Results 1 to 4 of 4
Thread: VH command not working on PRT 4g board.
    May 2004
    Default VH command not working on PRT 4g board.
    Machine: PRT with 4g upgrade
    Software: SB3 version 3.6.46
    Problem: Torch height control only sends z axis down, never up despite input #1 being high or low.
    Diagnostic steps taken:
    (I) Conducted Torch Height Diagnostic test from Shopbot docs.
    1. Enable torch height control with VN,,,1
    2. Turn on height control with VH,1
    3. Make a move in the x or y axis
    4. Z-axis should rise
    5. Use a jumper wire between #1 INPUT and ground
    6. Z-axis should drop
    (Results: Z-axis never rises, only drops)
    (II) Created toolpath using Partwizard and Shopbot plasma post.
    (Results: THC inputs recognized, operates as expected, except z-axis only drops)
    (III) Ran test on Shopbot versions 3.5.10 and 3.6.46
    (Results: same Z-axis never rises, only drops)
    Observations:
    It seems to be a firmware problem.
    I base this statement on the fact that you can see all the inputs go high and low in the SB3 control panel, which implies all the hardware checks out.
    Summary:
    I know plasma is legacy hardware to shopbot and no longer supported, however the [VH] and [VN] commands are still in the current Shopbot command Reference and should operate as stated.
    I'm at a dead end, please help!
    Daniel
    7equivalents@gmail.com
    May 2004
    To add to the diagnostics. The [VH] command will not stay set on any of the 4g firmwares. I ran the old PRT standard firmware 3.4.27 and at least the [VH] command stays set on it....
    Does this mean the [VH] command has been disabled in the firmware for 4g boards?
    Oct 2000
    Willis Wharf, VA
    Hey Daniel,
    Your best bet for getting useful info is to contact tech support at ShopBot.
    Bill
    May 2004
    Thanks Bill, I'm doing that today. I also reached out to Chris Burns. I know plasma is legacy, but the VH, VN commands are still current in the Command Reference manual, so should operate in theory.
